Suffering
Bluethunder3320
he says someone told him "it needs a new head"
i forgot what motor it was but its an old airiens mower.
r97
Measure twice cut once
Massachusetts, USA
my mower does the same thing, but it doesn't bother me, and i read it was most likely a bad coil, or the valves were not seating correctly or something.
Sometimes a coil that's on it's way out will quit working when it's hot, and then resume functioning when it cools off. I've seen it happen a couple times, I just don't understand why. Perhaps temperature can affect resistance values. Take a cold reading across the coil, then run it 'till it quits and re-read immediately...
Bluethunder3320
thnks ill probably just throw on an old coil i have laying around and see if it helps or adjust the one thats on first.
