Substitute V belts for 40 Series ?
Jim-L-L
South Australia
Hi All,
Question, has anyone worked out any substitutes belt sizes for 40 series CVTs ? I want to add flanges on my Kumquat buggy for possible future upgrade to 13hp clone with the idea of using a 40 series clone, my distance between centres would be about 9" or 10", But my Scottish heart will not come to term with paying $80 + to get a belt from the US to Australia, so can anyone provide the belt specs metric, imperial, angle, pitch etc ? based on previous experience most belts come from an industrial back ground, I had great success a couple years back finding tiny belts for a RC car mod that had people stumped for years (from photocopiers at a fraction of the price) but this had me stumped. I come from a parts sourcing background (aviation) and it gives me the pips when manufactures put their own part numbers on standard commercial parts ($$$$$)
Please let me know
Cheers Jim
The dimensions of a 40 belt are very specific. I have felt your pain buying a replacement, with not many alternatives. I can tell you this- aside from the genuine Comet article, there are not many alternatives. I honestly don't know what the clone market looks like, whether you can get one or maybe even the chinese 40's use "real" belts. Way back, I had a belt from Gates Manufacturing, but even WITH the part number in hand, I could not nail down a replacement. I even went to snowmobile and ATV shops because they have CVT belts.
I can tell you the top width of the belt must be 7/8", and the angle of the sides is 30* (15* per side, symmetrical profile). Thickness is 0.45". Exact length is based on exact center distance.
Jim-L-L
South Australia
Thanks Guys,
Valuable feedback
what is on offer as 40 series belt in Australia is a # 811-22-30 for about $35 (probably 1/2 that if I can find source)
Broken down 811 mm = 31.93" (OEM Comet is 31.950")
"22" is pretty close to 7/8 = 22.250mm
and the " 30' " = 15' & 15' (same as US OEM)
How does that line up with what on offer ? would it cause a problem ie. high belt wear ?
Please let me know
Thanks Jim
That my just work. The "local" belt is narrower, yes? It may slightly affect the ratios and shift points, but the unit would probably behave as if a factory belt is a bit worn. I don't foresee a big issue with that. As for the belt length, I belive that will be fine. IIRC, the Comet spec is for the O/C distance to be within 1/8" or something anyhow. Therefore, 0.02" in circumference is well within this tolerance. Heck- I bet the OEM belts aren't all within 20 thou!
I say you're good.
Jim-L-L
South Australia
Thanks, I guess if I have the right section I might be able to find one in a length that will work ! research continues
Cheers Jim
Do us a favour- post what you find in full detail, including a performance review. I'm sure there are members in similar situations (esp our other Aussie friends) that would be more than grateful for the information!
Jim-L-L
South Australia
Shall do mate, I am only in design stage now but will keep researching alternate belts, thinking about making the extra jack shaft mounts on my Kumquat slotted so I can dial in the distance between centres, it might take a while but will get there eventually.
Cheers Jim
