Subaru Robin with 16 tooth cluth
RationalOne
Would it be better for me to have top end over acceleration how extream can i make it like is 18 tooth too much?
(no hills and mainly stright aways unless i wanna make corners 10 in hoosers slicks on back and 8 inch slicks on the front its subaru robin 6.5 on like the smallest frame avliable
Hi and welcome
We need a lot more info..
since with what you told us so far..
(6.5horse engine, 16T clutch)
The answer is a solid: NOPE!
So, weight of the kart with you on:
outside diameter of the rear (driven) wheels
and toothcount of the axle sprocket please
And a list of all the mods that had been done to the engine.
(no mods.. see above)
I smell a "I want 60mph" gearing, and that's not going to happen too soon.
I would also have to say no with a 16T. To have a maybe decent (but probably not) gearing, you would have to have at least a 92T axle sprocket (to get 6:1 gear ratio). And with a minibike that isn't going to happen because you will be riding on the sprocket and not the back wheel due to its large diameter. You are going to have to go small tooth count on the clutch and large on the axle sprocket.
Answer some of the questions that Itsid was asking and we will be able to help you further
