Subaru Robin / Manco 607C Newbie Question
HavaFun
Hi all,
My kids got a Manco 607c with a Subaru Robin in it. Unfortunately, the belt shredded today, and I need to replace it.
Now for the newbie question: What is the easiest way to remove the pulley in order to replace the belt? Is it easier to replace the drive pulley, or the driven pulley? Do I need any special tools?
Any help is greatly appreciated.
Thanks in advance for your assistance.
Steve
smgs92
you don't need to remove it you just have to squeeze it on there its easiest to start with the expanding end
qtband
St. Louis, MO
:iagree:
...and welcome to the forum. Gently spread the large driven pulley (you will have to rotate it a little as you spread it) and put the belt on. Should be pretty easy.
Just a thought, wouldn't it be easier to fit the belt to the driver first (as the belt doesn't fit tight around it when staic) then run it onto the driven?
HavaFun
My second concern... I looked up the specs on the 607c Manco cart, and it says the replacement belt is a 5959... However on what's left of the shredded belt belt are the numbers 1904 (or 1903) and then the number 383. I ordered the 5959 replacement already, but they haven't arrived. Do I have anything to worry about? How do I know for certain I have the right belt?
Sorry for all the questions. I am still learning.
smgs92
nope it's just different brands i think it was either manco or comet that has the 5959 but you just have a different branded belt i believe
HavaFun
I installed the new belts and I spread the driven pulley by rotating it, but it only seems to spread about half way compared to what it seems. The belt drops in, but it comes right back out. Any ideas on how I can spread the pulley completely? I have a feeling that once I spread the pulley all the way, the belt will drop all the way into the driven pulley, and all will be good.
Should I remove the torque a verter and outside pulley, put the belt in, and then reassemble?
Thanks for all the help!
minichoper
The belt it suppose to rest on the outtermost portion of the driven. It rides on the wedding ring in the drive pulley. And its suppose to be loose at idle
i just zip the drive pully bolt off slide the outter off, install the belt, zip the outter half back on. Done
HavaFun
Thank you. Do I need to use an air gun or is there a way to remove it with manual tools? I am asking because I don't have any air tools with me, and my house is a few hundred miles away.
minichoper
A couple ways to do it. Get some nylon rope, remove the spark plug, insert the rope into the hole. This will act as a piston stop allowing you to remove the bolt.
HavaFun
Thanks minichoper. I actually used a wrench with a hammer... Manual "impact" wrench so to speak... lol Anyway. I figured out the problem. I ordered two belts so I would have a spare. Turns out one was mis-packaged. It is the right length, but just a bit too wide. This was causing it to engage. I put the other belt on and all is good. Kids are back out having fun again.
Thanks everyone!
