Subaru Robin 7 hp engine not running Right
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
I have a Subaru robin 7 hp engine on my go kart ("engines not much different then a Honda") and took it for a test and the engine doesn't sound right like as if it's skips a cycle. This engine is used off a old pressure washer its almost a new engine. And it dose not stay running when I fire it up it runs for like 8 seconds then dies. Only mod to this engine is a exhaust I made which has barely any restriction /pictures below/. I was thinking with the better flow of air that it needs more fuel in the combination? I don't no maybe some of you have had this similar problem ? Let me no Thanks
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
If it only runs for like 10 seconds it is probably the carb needs cleaned not the new muffler.
Staff Murderator
But the 90° angle on your header is not helping flow all that much. You need a curve~
