frostyflammable
This engine came off the go kart I am still restoring. I managed to get a free baja dirtbug (pics to come, not starting anything with it until I finish my go kart first) but the Subaru/Robin engine was not running all of a sudden. I ran it Saturday just fine, yesterday no dice... no matter what I did it would not start. So today I got to troubleshooting and first I though maybe the carb was dirty, however it looked clean but I cleaned it anyways, nada. So I started checking the three things an engine needs to run. It had fuel, it had air/compression but when I took the spark plug out and grounded it while turning the engine, nothing. No spark whatsoever. After digging even further I found the coil was good it was the cable from the coil to the plug that was bad. I put a multimeter on it from one end to the other and no continuity. So I cut about half an inch off of it since I felt no wire and once I did that I had continuity and could see spark. Put the engine back together and one pull she was alive.
So basically all this long story to ask this, since I cut the spark plug cable (on the coil side) and even though it is still plenty long will it be fine to just leave it shorter than what originally was or should I invest in a new cable?
Thanks,
Dan
Thanks,
Dan
