subaru ex27 9 hp help conclusion :)
umahunter
Awhile back I posted that I had a subaru ex27 9 hp I added a new 22mm mikuni carb with adapters. engine sounded to be idling fine but the tach sad it was at 2500 took carb apart cleaned same result. so I finally took the tiny tach off my other engine and hooked it up started her up and was reading 1200 rpm while the cheapie off amazon still read 2500 plus no matter which way I set it guess moral of the story never buy a cheap tach lol thanks to all those that helped :) :) :) would have updated my other thread but it was locked
My $10 tach works fine on my 4 stroke. RPMs match Speedo which matches GPS. I idle around 1850 RPM and can get it up to 5050 RPM.
Are you sure it's installed correctly... They are cheap... But typically not that way off of a reading...
umahunter
hmm
I tried it three or four times set different was same result I was gonna mess with it again last night and it was dead I finally got it where it seemed to be about 1000 off from my other tach I may mess with it again after I get another battery
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Couldit be a two stroke tach. So its computer is counting the sparks and then doing the math wrong? Almost sounds like it is doubling the RPM count. 1200*2 is 2400.
umahunter
Hmm
It is supposed to work for 2 or 4 but I set it both ways and it didn't make a difference I'm gonna mess with it again maybe I got a bad one
