Subaru carb jet questions?
NBraun
Ok, well we have just installed a new cone filter and header on a subaru robin 6.5HP engine. It ran fine before but now it just starts and dies. We immediately expected the jets. From what ive read we could just drill out the main, or adjust the pilot. How do we "adjust" the pilot? We are going to do some plug readings tomorrow. On another note, where can we buy jets for this carb? (its a Mikuni)? Thanks in advance for and tips on our problem or the jets!
Russ2251
AZUSA:Powered by LAWN-BOY
Unlikely this is causing your dying problem. Engine should run fine with no filter. A header may cause it to misfire but not die.
If jets do fix the problem, all that means to me is that you may have inadvertently fixed something else.
A true test would be to return engine back to original and see if problem persists.
NBraun
Well, what happens is if it on choke it will idle very rough, but if you take it off it will rev up and then die. If you take the choke off and slighty push the gas about half-way it dies. BUT if you slam the gas and go WOT it runs smoother and it drives. We did a couple of WOT pulls and checked the plug, and it seems to be running rich. Here are some videos of our problem.
