Subaru 7hp engine help
JokersAce69
Mesa, Az
Robin subaru ex21 7hp. It's ran flawlessly up until 2010 i stored it like an idiot with gas still in the tank and no stabilizer. I'm also sure the oil is bad. So recently i felt the need fix this engine and give it lookover. There is good compression, decent spark, cleaned out the tank and screen, tried to fire it up and no go. It will only start if i spray gas inside the spark plug hole but it dies within a second.
So i took apart the carb (touched no settings. Sprayed it out with an air compressor and still nothing. The bowl has gas inside i just don't think it's making it's way into the engine. I'm going to the store to get some new oil and a spark plug.
Any help would be much appreciated, thank you!
Also wanted to add that the throttle plate is bent on one side and leaves a small gap. I've never messed with this carb. I'm not so sure it should be bent, all the plates i've seen are flat. What should i do?
MARGR4V3Z
MICHIGAN
Sounds like your Carb is gummed up and needs to be taking completely apart and most likely rebuild. Spray all holes with Carb Cleaner and use a thin wire to clean out the Jets. After all that then blow it out with compressed air. Should see better results after all that is completed.
JokersAce69
Mesa, Az
Nevermind, i made a newbie mistake. I changed the oil and I striped the carb down completely and sprayed all of it with carb cleaner. Then i noticed the main fuel jet has gunk all over it. So i used some wire and pushed all the gunk out of the hole re-assembled and presto runs like a champ. Hooray!
JokersAce69
Mesa, Az
Yeah i know i thought i was SOL. Now the only problem with this engine is the pull starter assembly is destroyed. And parts are near impossible to find. A new assembly would cost me $100.
JokersAce69
Mesa, Az
The ratchet guides, spiral spring, Return springs and the rope are broke i also manager to crack the reel in a few spots. It happened years ago. When i was out riding i happened to get the starter knob hung up on a branch. Wasn't a pretty site. When i was going to replace it i ordered from an online dealer. A month and a half later nothing was shipped and they hadn't even started the order so i got a refund and just never got back to doing it.
