JokersAce69
Robin subaru ex21 7hp. It's ran flawlessly up until 2010 i stored it like an idiot with gas still in the tank and no stabilizer. I'm also sure the oil is bad. So recently i felt the need fix this engine and give it lookover. There is good compression, decent spark, cleaned out the tank and screen, tried to fire it up and no go. It will only start if i spray gas inside the spark plug hole but it dies within a second.
So i took apart the carb (touched no settings. Sprayed it out with an air compressor and still nothing. The bowl has gas inside i just don't think it's making it's way into the engine. I'm going to the store to get some new oil and a spark plug.
Any help would be much appreciated, thank you!
Also wanted to add that the throttle plate is bent on one side and leaves a small gap. I've never messed with this carb. I'm not so sure it should be bent, all the plates i've seen are flat. What should i do?
