Stuck clutch
bandon
Hi guys. Newbie here. I received a fairly new Honda 6.5 horse engine from a friend of mine and the clutch appears to be stuck. Both of the set screws are missing..and there is no bolt holding the clutch onto the drive shaft. Tried levering the clutch off with no dice. So..need some advice freeing this item. I have included a photo. Thanks in advance.
Get a ton of WD-40, Fluid film, Forte, or whatever in there and let it soak in. Re-soad it every several hours, for a total of a day or so. Do you have access to a 3-jaw gear puller?
Bluethunder3320
i bought a gear puller for this kind of stuff. cost me about $20 on amazon i think. i use it all the time! and its big enough to do some flywheels too.
it looks like right in front of the clutch on the shaft, where the keyway is, some metal is peened up... try filing it down or use a dremel.
my friend got half a comet driver stuck on his clone, the springs and outer part were wrecked anyways so we just cut it off in many pieces with a grinder. it wouldnt come off no matter how hard we pryed it (this was before i got my gear puller)
HellSpawn
Wadena, Minnesota
If its stuck really bad, sometimes a puller is a bad idea if you're trying to salvage the clutch. (Can easily destroy the thing with the amount of force pullers apply.) I'd just keep on soaking it with WD-40 or even some Liquid Wrench (pretty expensive stuff but it is much much better than WD-40 imo) and try to work it off with a pickle fork. Check if the end of the shaft is mushroomed over from someone beating on it with a hammer, if it is. take a file to it and until it is true again.
Bluethunder3320
anyone else see how the corner of the keyway is damaged a little?
r97
Measure twice cut once
Massachusetts, USA
If the key broke it is possible that part of the key or another object got jammed between the clutch and your crank. I have had the happen and it was not easy to get off, although a puller would have done it no problem. If this is the case your crank shaft and clutch are probably all scratched up.
crazyman
Yorkville Il
Screw a bolt that's head is smaller than the shaft in with no washer and use an air hammer on the bolt while pulling on the clutch with your hands. Sometimes this is the only way to get an electric PTO clutch off a riding lawnmower.
