Troikos
Electric Reverse
So I've been tossing this idea around for a few weeks now about using a stepper motor in the drive system. Its primary purpose would be for electric reverse as well as electric brakes and I was wondering what the groups thoughts on this would be. Power systems aside (already have them planned and not really relevant), How practical would would an application like this be?
Motor Specifications:
Frame Size: NEMA42
Step Angle: 1.8 degree
Voltage: 5.86VDC
Current: 8.0 A/phase
Resistance: 0.67Ohm/phase
Inductance: 12mH/phase
Holding torque: 300Kg-cm 4120oz-in
Rotor inertia: 1620 g-cm2
Number of wire leads: 4
Weight: 11.7kg
Length: 201mm
I especially like the NEMA42 motors because of their extremely high torque and 3/4" keyed shafts. Even though the motors are only rated for 3-5 volts they are typically driven with 24-80 volts dc with current limiters.
Here is a graph of a typical stepper motor torque curve. I couldn't find one for a comparable motor but the curve is similar on all of them. Basically, the torque goes down as speed goes up which is why I think it would only be practical for an electric reverse.
Thinking I could use it as a brake because my vehicles are remote controlled so it would be easier to just energize the coils in the motor to stop the vehicle than rig up some sort of mechanical system.
Thanks for the read, here is an obligatory video feature stepper motors playing music with their resonance.
http://www.youtube.com/watch?v=Xk_XaJ7gE4Q
Frame Size: NEMA42
Voltage: 5.86VDC
Weight: 11.7kg
Length: 201mm
