Stephen115's homemade kart
Stephen115
I'll post some in a bit. Got it pretty much dialed in today, rode it around the block a couple of time and it is defenetly not safe for the neighborhood. I'll be taking it some place else to ride it.
I do know that I need more/better brakes anyone have any ideas?
thomas
Where did you,get the bearing-retainers?? I"m local( OKC),and would like to know,if tractor supply has these..
thomas
I live,in OKC,too..I picked up the rest of the 11.00-6x5 tires,he had left..Now--I"m trying to find rims for them..A lot,has changed here,since 1995,-The last time I lived here,There was a Kart Shop,on every corner..(not really,but you know,what I mean!!)..Do you know,of any local mower shops,that still carry parts? So far- I"ve bought a half-dozen clutches,from tractor-supply,and they last about 2 weeks-with my kids,and grand-kids..
NOT worth the 500,a pop,I"m spending....
Stephen115
I get my oil mixtures from Heartland cycles on shields in OKC. I ordered almost all my parts from ebay and bmikarting.com. there are no shops around that had what I was looking for. besides the misc. key ways and nuts and bolts. O'reiley's carries clutches for 35-41 chains if thats what you need. the bearing set i got off ebay: http://www.ebay.com/itm/1-Rear-Axle...ts&hash=item2c6634842e&vxp=mtr#ht_1049wt_1163
These are the wheels for the 6'' tires that I got from that guy: http://www.bmikarts.com/item/5-Douglas-Polished-Aluminum-Wheels-675-3364
and the 1'' hubs to go with: http://www.bmikarts.com/item/Lightened-Aluminum-Rear-Wheel-Hub---1-or-1-14-600225-or-600230-2
for the 5 inch skinnies in the front I have these:http://www.bmikarts.com/item/5-Douglas-Polished-Aluminum-Front-Wheel-675300-6172
I hope this helps
SJ
Stephen115
I wired the kill switch, ground to the frame and power to the spark plug but it didn't work. is there any way I can wire a kill switch to the coil to shut it down?
EvoDre
was the kill switch wired between the cdi and the coil? do a write up on how you wired it in let me see if i can help you out!
EvoDre
idk how to explain it but post up a pic and i will do a write up for you!
thomas
BTW- I"m selling off,my entire collection-wheels,tires,racing parts,etc..Come on down,to exit 143,turn left,first driveway,on your left..Honda gx 450 5.5 hp engine,sitting on a frame,and -early 60"s Go Kart 400 junior frame-many parts included..300 dollars,cash.. call me-405-651-0832....OR-take the 143 exit,turn left,go to first gravel drive,on your left,second home,on the left....Injury forces sale..
EC1
White/black wire on one side of the kill switch and ground to the other side.
EC1
So how does she run? Any flat spots in the powerband? How does the jetting feel to you? Great work!
Stephen115
This is the first kart I've drove that has this much power. Its fast I can feel the power band kick in and everything. Runs good as far as I know
Stephen115
Sorry to hear about your injury but I've got three kart projects right now and I'm not looking for anymore stuff right now, thanks
Stephen115
I did the black/white to the power on the switch and then ground to the frame and all that happened was the little red light on the switch came on. what did I do wrong?
Stephen115
Worked on the exhaust today. it doesnt really make it any quieter so i'm going to get a real muffler not a glasspack.
SJ
exenos
Project Nut
Ya, you will really notice when the tuned pipe kicks in because of the exhaust extension between it and the engine, throws the timing off and shortens the power band.
