steering problems
alex1234
i recently purchased a buggy locally which i dont know alot about.
i had it out today, the wheels just want to turn too the right.
One of the wheels turns right but the other turns alot further right which isnt right, the steering is hard to keep control of as the wheels go to the right position and it is hard to keep it straight
its been made with handle bars not a steering wheel,
i have a photo of my buggy which is below, and i will take a photo of the position that the wheels go too, hope someone can help
alex1234
oh thats right, it was straightened but still keeps doin this problem also ive put suspension too the front now, the rods are flimsy but even when goin full lock its all over the place
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
Have you actually set the toe since you straightened the tie rod? Looks like there should be some shocks on the front....
alex1234
hi, i have put suspension on it and it still is doin this problem i will try get a better photo of what the wheels are doing tomorrow
theo
You might have a ackerman problem and when you use the suspension, you have real bad bump steer. Remove the steel tubing and cycle the suspension and see how much toe out you get when the suspension goes up and down.
alex1234
here is a couple of photos of the way it goes they aint very good but its all i could get at the moment as its in the back of my garage,
Rickracer
Kissimmee Fl.
Looks to me like the caster is backwards. The tires should NOT lay over like that when you turn. Kinda hard to tell from the pics, but I think you might wanna try swapping the lower a-arms from side to side then set the toe. :confused:
