Steering problems
smithky
Hi all i just recently brought a go kart 2nd hand after getting engine running smoothly im having problems with steering the problem is when i turn one way it works fine no issues when i turn the other way it lifts the front left hand side wheel off the ground which affects steering greatly any idea what can cause this? Thanks
There's lots that can cause it- Everything from bad frontend geometry to a bent or twisted frame. Post some good pics of your frontend componentry. Get yourself a straightedge, a string, and a tape measure. Take lots of measurements from one side of the frame to the other and compare them. If you look at things VERY closely, you should ultimately find the problem.
To give you an idea, I had the exact same problem on the Alley Kat. Closer inspection revealed that the front axle was bent upwards and back VERY slightly on one side... And that's all it takes.
