steering adjustment
ghogan
I have a older kart, live rear axle (solid, both wheels turn the same time). it has the simple ackerman steering with adjustable tie rods. the kids hit a tree and bent one of the steering arms. I bent it back & I tried adjusting it, but it really binds up when turning into a corner. Is there a step by step approach on how I can adjust the tie rods to keep it from doing this? do you recommend toe in or toe out? I'm not racing this thing, just want it to be able to make the corner. right now, its so bad the engine does not have enough power to force it through the corners since the wheels seem to be fighting each other
any help or direction would be appreciated.
thanks
huttronics0001
i had a live axle with terrible handling. but when i took the key way out of the right rear wheel so it could spin freely it improved most.
I cant really give you tips on the actual steering unless i see it myself, a pic would be useful. but have someone turn the steering wheel while you look at the damaged area and try to identify exactly what is making it bind up, then see if you can fix it.
(I've custom built 3 steerings on my go kart)
huttronics0001
Hutt, you shouldn't need to run keyless on one side to gain acceptable steering. Never mind what that's going to do to your hub and axle shaft, it just shouldn't be necessary. Easier, yes. You probably know what's involved so I won't go into detail, but I will say this: Even on asphalt, my live axle offroad kart practically handles like it's on rails. And there's STILL an improvement I have yet to make. But, let's see what Ghogan gives us to work with...
ghogan
Are you able to determine exactly which component is binding, and when? Got a pic?
Here you go..., I think the wheels are traveling at differnet speeds around a corner. I have had som etell me that with a live axle there is not much you can do about it
thanks
The wheels are most definately travelling at different speeds around a curve- no question. A live axle (without a differential) does make things a tad bit more difficult. There are several things you can do to make such a rig steer better, but lets get back to your original problem. You suggested that a frontal collision caused you steering issues. So- Tell us what got mangled, what you think is binding, and some pics.
