Does anyone know of a Stator magneto that could be put on a 6.5 clone engine to provide a charging system for lights. I have tried goggling it and haven't been able to find anything
Your search results will likely be more successful if you use the term "Charging Coil", as I believe they are properly known as. You can also look for electric start kits for your engine as they will have all the goodies including the coil and if you're lucky you might even score a part number.
Hey guys thank so much I'll check out a charging coil. Also I have a problem with a shudder when I first take off; I have a centrifucal clutch chain driven to jack shaft then to rear wheel..........
