Starting Point For Idle And Main Jets
OneTimeUser
Texas
I'll start again by saying the search function does not work (or work very well) for me. So forgive me if this question has already been beaten to death in other threads.
What I'm asking for is a knowledgeable guesstimate at idle and main jet starting points for my (soon to be) new set up.
Set up: Tillotson 212 with 24mm Nibbi and free flow exhaust with a hot dog muffler.
I've got a pretty good assortment of jets, I'd just like to take some guess work out of the starting point.
Thanks in advance.
Sparkwizard
Richlands ,NC USA
Not a racer, but I usually try them as delivered, right out of the box. I check float height, all screws lighly bottomed, then 1.5 turns out.
BUT...I am a 2 stroke guy, so most of my performance carbs are Tillotson pumpers. I don't swap jets on them, I just twist a screw and keep on riding.:banana::banana::banana:
What kind of Nibbi?
Id start with a 28 and 75.
My ported/modded 196 has a 35 and 90
My ported modded 212 has a 42 and 85. I think im a little lean towards the very top end.
OneTimeUser
Texas
Round slide 24mm Nibbi. I went with 35 pilot and 125 main. Runs pretty well, but starts kinda hard. Idles fine.
I may up a number or two on each. Won't start without choke even when hot.
The Tillotson is stock inside except for governor removal.
Every engine I own needs to be choked to start, hot or cold. I wouldn't worry about it. Concentrate on throttle response and reading the plug.
OneTimeUser
Texas
The whole purpose (for me) for electric start was that I can just hop in the thing and go. If I have to stand in the back and mess with the choke I might as well just pull start it. So, gonna either figure out how to get it to start sans choke (at least while hot) or get a cable set up.
I think I may have caused this problem by going with a 24mm Nibbi instead of a 22mm. Not sure.
I don't think it's an exaggeration to say that the future of the free world hinges on my finding a solution to this problem.
Here is a picture of my key set up. Spiral wire wrap to tidy up is on its way from that bit A in the sky.
Empty tin can is (duh) my coffee cup holder.
Yellow overspray is a fairly rare and highly coveted factory option.
Get a remote choke. Run a choke cable to the ”dash” or where your control panel is. All you need is a generic rigid wire choke cable, a Z bend formed on the end, a hole drilled into the end of the choke lever (about a 1/16” drill?) and some cable clamps (mount one on the blower cover or engine tins and the other at the controls).
Agreed on the convenience of electric start from the driver seat. I’ll tell you another benefit, it is way too common around here hearing about runaway karts. You’re at the rear of the kart pulling the rope, it starts and it takes off on you. This happens all too often for myriad reasons: stuck throttle cable, broken throttle return spring, faulty clutch, etc.
Whoops, does the Nibbi have a traditional choke lever?
OneTimeUser
Texas
Thanks. The Nibbi has a straight pull up knob. I found a complete pre made cable kit for the Nibbi with the screw on cap, cable, and the little brass plunger dohickey for sale for $40 or so bucks. I'm going to try to make one DIY. If I F it up, I'll buy the kit.
And, I've had the run away cart thing happen with this very cart. Up the ramp to the shop, caught a bit of air, and slammed into the frame for the garage door about a foot off the ground. It broke the left front wheel suspension completely off the frame. Whoops. Lesson learned. I posted pictures of the point of impact on the garage door frame awhile ago in another thread when someone doubted my story.
I blame the runaway on a cheap clutch that was stuck in "high" gear. I put a super series 30 clutch on it and am much happier with the way it works. Once is enough for that run away so I now set the parking brake (every time) when I pull start it.
OneTimeUser
Texas
Found the Nibbi kit to convert to cable for $15. Ordered from GPS. Yay. Comes with no cable but that's not a problem.
After an hour or two of break in the Tillotson is now starting and running very well with 35 and 125 jets. It's got much more pull than the Predator did--although in fairness I don't know the history on this particular Predator. It sat for (many?) years before I got it and may have many hours on it.
