starting crazy kart
18HPHalftrack
ok, i have a 18hp mower engine and im planning on makeing a 6wd kart(not including the front) well i have it planned out the gearing, bearings, frame but having a little trouble thinking of the back suspension and all these little things like shims?? and bushings?? sry but i never used this stuff before and wat would keep the axle from sliding side to side on the bearings?
18HPHalftrack
also, with the suspension, how will the axle and wheels come up without pulling on the chain? i mean the axle doesnt go straight up it goes up and back a little
jeff_man
so your going to have 6 wheels in the back, are all of the six going to be powered and is this mower engine vertical or horizontal shaft
robin
in a house
man thats gona be one sweet *** project if you make it work unles you have geers i dont think ur gona go fast with all them wheels personaly i wouldent use suspention just huge tires and dont pump them up much
18HPHalftrack
ok, i didnt no if soft tires would be good suspension, but i been redesigning and thinking mayb 4wheels in back for more speed and less weight and shorter length
jeff_man
so your probably go with a differental axle so you could use a leaf spring suspensions simple, like trailer design suspension
18HPHalftrack
also, are wheel hubs without bearings and a keyshaft for mounting the wheels to the axle so the wheel spins?
jeff_man
nothing wrong with that just single wheel drive is not very good for off road and yeah thats how the wheel spins
jeff_man
you could use independant suspension with the differental with 1 inch output shafts and using double a arms with cvs or u joints
18HPHalftrack
ya, but ill do alot of tooling and try not as much spending lol, also i dont want single wheel drive i want the axle spinning and both wheels
jeff_man
well both will be pretty spendy but the cheaper one would be leaf spring suspension
18HPHalftrack
ya i guess, but i never really seen trailer leaf spring suspension, im thinking j big tires because i never have done this before
