Square tubing or round tubing?
ferhankov
Victoria, Australia
So I have a framework and all ready, however with some welders the question rose of does it matter if the frameworks made out of round tubing or square galvanised steel?
firemanjim
Just kartin' around....
Houston Texas
It doesn't matter if its round or square, but DO NOT use galvanized tube. Welding on it will put out a HIGHLY toxic fumes if im not mistaken. The metal need not be galvanized anyway. Everybody paints their karts...
Half-breeder
"Edit" button removed
So there wouldn't be any major weight difference or anything that'll cause a problem?
...major weight difference(dependant on the thickness and diameter) I wouldnt say 'major'...square tends to take up more space(inch for inch of same thickness) which tends to add more weight(a pound here...a pound there).
cause a problem?.... not enough to 'call' it a problem no... just the weight 'issue'.
Square IS by far easier to keep lined up when welding and more surface area than round= more/better weld(which equates to better chance your frame'll be 'square' and staying that way w/ a heavy load)...but forget about making a 'pretty' curve/bend w/ it. IMO I think square tube karts kinda give off that '8bit' look to em.
ak99
Queensland, Australia
Nope. Square tubing is easier to weld. You dont have to fishmouth all the joins
I agree with this, especially with my welding skills!
As the OP is here in Australia - My frame is made with 25x25 square tube, built using a Chinese arc welder with decent rods and it was easy to build. I do have a cut off saw so the cuts are nice and square.
Total cost for the tubing was $35, the frame is large enough for me - I'm 6ft 2"
My daughters frame is 1" SHS, mine is 1" round tube so, I can tell you, square is easier to work with but, it depends on the style of kart you're buildin as to what you use.
For some, either will work; for instance, I could easily have made my daughters from square or round but mine wouldn't look anywhere near as good if I'd used square tube...
