Sprockets!
TripleT
Iowa
I have so many questions. If you have a larger sprocket will you get better take off than a smaller sprocket? and if you have a smaller sprocket will you get better take off than a larger sprocket?
Jake.B
California-USA
Lets say you have a 10 tooth clutch. The smaller your sprocket on you axle the faster top speed but not as much acceleration. The larger the sprocket the better acceleration but lower top speed. If your axle sprocket is too small it will burn your cluutch up.
kmy
Play with the SPEED CALCULATOR on this site. It really help gets an idea of what sprockets you want in terms of speed.
