So i have this skinny narrow go kart that has an expensive atv axle (so cant replacing it).Which has a 31 tooth sprocket and the only torque converter(TAV2) i can afford right now has 12 tooth sprocket. The axle has the sprocket welded together so its not going anywhere and i cant find any other larger sprockets.So that is staying which means my ratio is close to 3:1 and 12in tire diameter how is that going to handle on the road and off road (no hills) i live in Texas not much hills. I also have an 212cc predator engine i just bought and it will need to be costume mounted because there is no room on go kart i will post pics later.
and i still haven't checked if its ok
It has a few problems but nothing that can't be fixed...
