sprocket pitch?
Texas
How do i know what the pitch is on my sprocket? Im not into chain drivin items, so advice would help. thanks
denhammotors
Stuart, Florida
Measure the distance between teeth. That distance is the chain pitch. The first number of a chain represents how many 1/8" that the chain pitch is. For example, #35 chain has a 3/8" pitch.
Texas
That was very helpful, although i still have a problem on ebay finding a sptocket with a 5/8 pitch to fit a 525 chain with a 1in bore with a keyway.
denhammotors
Stuart, Florida
A #525 chain has the same pitch as chains #50, 520, and 530. The only difference is that 530 and 50 sprockets are too thick for 525 and 520 chain. If you're having trouble finding a #525 sprocket, try looking for #520.
denhammotors
Stuart, Florida
You could make a hub for it yourself, but a less tricky solution would be to switch to using #530 or #50 chain. You will be able to use a 50 sprocket (easy to find with 1" bore) and also be able to use your existing #525 sprockets.
