Measure the distance between teeth. That distance is the chain pitch. The first number of a chain represents how many 1/8" that the chain pitch is. For example, #35 chain has a 3/8" pitch.
A #525 chain has the same pitch as chains #50, 520, and 530. The only difference is that 530 and 50 sprockets are too thick for 525 and 520 chain. If you're having trouble finding a #525 sprocket, try looking for #520.
You could make a hub for it yourself, but a less tricky solution would be to switch to using #530 or #50 chain. You will be able to use a 50 sprocket (easy to find with 1" bore) and also be able to use your existing #525 sprockets.
