sprocket gearing
kartsandatvs
San Antonio, TX , USA
Hello forum, I am a newbie, have had experience with track karts using the 160gx 5.5 hp honda engine with a 4 to 1 relation which is really an 8 to 1 because of the wet clutch (2 to 1 relation ), I am now installing a clone 6.5 hp harbor freight engine on an old 3 wheeler, using a jacksaft to obtain a 10 to 1 relation and also because the kawasaki 3 wheeler uses #520 chain and the clutch uses #40 chain, so the jackshaft would have both the # 520 and the # 40 srockets ,my question would be what do you think of a 10 to 1 relation with 18 inch diameter rear tires and also what 3/4 centrifual clutch would you advise me to get good price and good working clutch, I know 3 wheelers are very instable so its mainly torque and not speed I am looking for I think, thanks
I think that setup should work fine but, it all depends on how big/heavy the 3 wheeler is; will a 6.5hp engine be strong enough? What was the original engine?
I would have to agree with Fabroman. The 10:1 should be OK with those tyres. I would go for it, and if it is not working out for you, you can always change one of the jackshaft sprockets to gear lower.
kartsandatvs
Thanks for your replies, the 3 wheeler had a 200 cc 2 cycle engine, the planned gearing would be 10-20-10-50 to get the 10 to 1 relation, maybe 10-30-10-50 would be a better starting point to get a 15 to 1 relation. Any good lasting 3/4 inch, 10 tooth centrifugal clutch in mind ? Thanks again
All of the name brand clutches are pretty good. Max torque is one that comes to mind
...& you're in luck, #40 3/4" clutches come in 10tooth :D
Going from a 200cc 2 stroke to a 200cc 4 stroke may sound like an even swap but, beileve me, it's not. Do some research on the original engine, I can almost guarantee it had a lot more than 7hp...
Knowing that, IMO, you may be better off with a slightly more expensive 4 stroke pit bike engine
kartsandatvs
Hello guys, tried the 10 to 1 ratio on the 3 wheeler this weekend and it worked great, I have pictures and a small video but dont know how to post them. I also noticed something else the camshaft on the 6.5 hp honda clone measure .7495 inches but the inner hole on the max torque clutch measured more than .7500 there was a gap that i was able to fill with 2 layers of a beer aluminum can, the gap was filled 90%. Please let me know how to post pictures and video, thanks
3/4" = 0.75" = 19.05mm. It's possible your shaft is only 19mm making a difference of 0.05mm or 0.002". If the shaft is slightly worn, that would, obviously, make the gap larger...
To post pics, read this. Vids need to be uploaded to a third party site like youtube then post the link here...
kartsandatvs
Hello guys, yep the hole on that max torque was a bit bigger, the thickness of the aluminum can is 3.5 thousands so the 2 sleeves that I rapped around the camshaft actually increased the shafts diameter by 14 thousands, anyway there is no gap anymore, thought it would be a good idea to share that with you. let me ask my sons how to include pictures on a video and i will send you the link. Have a great day and thanks for your replies , and yes the engine is brand new with a measurement of .7495 inches, i think it was machined perfectly.
