CRN13
Background: I built a motorized drift trike with a gx200 clone and a gear ration of 4.2:1 with a goal of achieving at least 40km/h. i did everything i could to get to 40 but i only managed 38, i cut every second fin of the flywheel, backed out the throttle stop screw, reduced weight, everthying i could think of and what i have seen suggested online. i eventually bit the bullet and i have ordered a billet flywheel and rod, 36lbs dual valve springs and stainless valves, so i can remove the govner and safely thrash it to pieces and get to my goal. (and hopefully like 60km/h)
My questions are these:
1, will using 36lbs valve spring break the stock rockers and do i need to buy reinforced ones im worried they will break and destroy everything; and
2, does anyone know how strong dual valve springs will be if i remove the inner spring and only use the outer one?
cheers for your help in advance
