Spider carts recluse, my first build
Goosethecartbuilder
the cart was made 1:1 with the scale of the plans i didn't expect it to be quite so small. that bushing you see on the steering rod is made by me out of some sort of nylon we had lying around the shop. the jack shaft makes the cart geared 6;1 with a smaller rear sprocket witch makes for more ground clearance, if you need more info on jack shafts my suggestion is to do your research and decide on what gear ratio you want then decide sprockets ect. the jack shaft can be hard to fit into a small cart but it is totally worth the trouble. cheers goose :auto:
Hybridyne
In the eyes of your 7 year old brothers, That is the most awesome kart in the hole world! You are truly a GREAT Big Brother and I am sure they will never forget what you did for them!
Bless You !!!
We do not encourage or condone the sharing of "paid for" plans, mainly because we don't encourage or condone breach of copyright laws...
Good day sir goose would it be possible if you could share the plan for this go kart? i want to build one for my daughter
The plans for the recluse are relatively cheap compared to what you will be paying for all the materials to make the kart. It is a good investment
Spiderkarts did release some plans for free a few years ago. I have the plan for the Itzy Bitzy kart if you would like them. They were distributed free, so I assume I can give them to you without a problem
You can also look at the plans on kartfabs website
http://kartfab.com/go-kart-plans
Goosethecartbuilder
It's worth it to buy plans vs. trying to build from scratch. I won't give out the plans I paid for simply because I know someone took the time and effort to draw/ design the plans, and I think they should be supported. Cheers, goose
