Ok got it makes sense the mount holes would line up then. I'm about to order it. You have been a major help in pointing me in right direction. I just ordered it and when it gets here I'll post back here to tell my progress !!!
Thanks again!
Well while it comes, ̶h̶e̶r̶e̶ ̶i̶s̶ ̶a̶ ̶l̶i̶t̶t̶l̶e̶ ̶t̶i̶p̶
a lot of tips. If you don't have an impact gun, which you likely don't, this will help you get the bolt off. Get a 1/2" wrench or whatever size is on the end. Use the box end of it(the closed end) and put it on, with the wrench tilted towards the engine, not towards you. That will make sure it stays on. Then you turn the motor until you can feel one of the compression strokes and the resistance from the crank will increase very significantly. Lastly , take a hammer, the bigger the better, and whack it loose.
To ensure the life of the belt, while you have the TAV apart, make sure to clean the inside of it and remove the rust. The rust will accelerate the wear. For the driver, I would take a wire brush and put the stationary sheave on the motor without the bolt and brush the dirt off. Put the TAV back together as if you were reassembling it but put the moving sheave on backwards. Now you can put the bolt in and clean, but do make sure you DO NOT rev the motor. That will likely result in damage to the TAV. For the Driven pulley, I took a 220 grit sanding sponge and shoved it hard into the pulley(the rust on mine was only around the outer edge) and pushed the kart back while maintaining pressure to prevent the sanding sponge from coming out. Having a helper would help out here a lot.
Also, while you have the machine apart, lubricate the TAV with dry lube. Don't use oil, it will need to be cleaned way too often. I do that with mine and the rubber particles turn the oil black in no time. Also clean everything with brake clean and lubricate the sliding driven in the back with oil if you want. Just make sure to not get any oil on the sheaves/clean the oil with brake clean or you will be going at 8mph because the belt will slip like it is right now. Pry the sheaves apart before dropping the oil in to prevent getting it on the sheaves.
If this doesn't cover everything you need to do when your new belt arrives and how to service your TAV, I don't know what does. When you are done, you gun it(giving yourself plenty of room to sort out problems and either slow down or turn off the motor, probably 500ft is suffice). If you are pushed back into your seat, accelerated like the wind, and going fast enough to reconsider your life insurance policy, well you did everything right
