Speed estimate vintage engine
TJ8
I recently found a 1979 Briggs 80202 engine. I plan to rebuild it and possibly do some mods. Any idea how fast I can get it to go if I build like a 20t sprocket?:wai:
Nowhere near enough info to go on, here.
An engine doesn't go fast- the vehicle does. Tell us about the vehicle. Type, size, weight, tire size, gearing, intended terrain and riding conditions, etc.
B.M.800
TheBeal.
Central PA
^^ Like he said, there are alot of things to consider.
If you want fast, your take off will be low, and you might aswell forget about hills. Possibly to a point where you will have to replace the clutch more often.
TJ8
Gear ratio
Is a 2:1 gear ratio dangerous? What type of speed are we looking at? I'm planing to machine a sprocket for a summer project. The engine I have is old and is 3 hp so I need the most speed possible. What is the best option?:stir:
TJ8
I havent built a frame yet, so I plan to do something for the most speed. plan to have either all 10 inch tires or 10 inch in the front and 13 in the back. I have access to a HAAS mill so I plan to machine the drive sprocket and the clutch is 13 Tooth. I plan to drive it on either a field or road. Any thoughts to get the top speed out of this? I'm new to this, i'm planning a summer project.:stir:
Don't expect too much. It's a 3hp engine. to get the most out of it, design a frame that is as lightweight as you can possibly muster, without building a deathtrap. Keep tire size to a minimum, 10 or 11" max.
Some engine mods can be done like removing the governor, porting, aspiration, etc. But again, it's a 3hp engine.
FWIW- I believe the governor on that engine is pneumatic- removal does not even require opening up the engine, just 30 seconds with the blower housing off...
TJ8
but like any top speed ideas what if the gear ratio was like 3:1 or 2:1
TJ8
What is a fried clutch? And then what is the lowest possible one you would recommend? I'm hearing two different stories about gear ratio size; which one makes the top speed higher? Smaller right?
A fried clutch is a clutch that has fried. Gearing too high causes excessive clutch slippage, and that equals heat. Heat destroys clutches.
Regarding gearing, I don't know what two stories you're hearing, but there's only one "story". Gearing to a lower ratio results in more torque/acceleration, and less top speed. higher gearing sacrifices torque but results in higher speed. Gearing two high cooks your clutch, if the engine even has enough grunt to get it moving. For clarity, a LOW ratio is numerically higher (say 6:1) and a HIGH ratio is lower numerically (say 3:1). Therefore, 6:1 is a LOWER gear ratio than 3:1.
Regarding actual sprocket size- a small clutch sprocket and big axle sprocket results in a lower gear ratio, whereas a large clutch sprocket and small axle sprocket results in a high ratio.
TJ8
so I want a small sprocket for a high ratio? Which means high top speed
For a high ratio, you want a larger clutch sprocket and smaller axle sprocket. And your kart probably won't move.
You see, ratios and speed are only theoretical. IF your engine does not have enough torque, you simply cannot reach the projected speed.
A little bit of friendly advice for you- forget gearing, it's too early. You need to gear for what you have, and right now you have nothing- other than a small, weak engine. You need to focus on a very small, very light frame, OR a bigger engine. Gearing comes later.
TJ8
Can you help me with something else then? So if I want to mount the sprocket to the wheel what do I do? like what does the hub connected to the wheel do with the sprocket, and how does this stay on the axle?
You should take some time, and enjoy a long stroll through this forum. Stuff like this is covered at great length, with lots of terrific examples to draw from. This is rudimentary stuff, and you need to familiarize yourself with it. Now, I have a question for you-
Can you weld, or have someone that can? Building a go kart frame is not a good candidate for your first welding job. In that case, you're best to buy a cheap used frame off Craigslist and build it up from there.
TJ8
I've been working all year on a high mileage car in school so yes. I'm quite proficent with a cnc mill, cnc lathe, and plasma cutter too. I just have not done anything specific with the stock engine and gear ratio. The drive wheel on our car is a bike wheel with a polycarb sprocket screwed in, and it is only one wheel so a two wheel go cart is a weird concept for me.
