SPD shift kit
matman55
I dont have a camera!!
Mims FL
http://www.sickbikeparts.com/catalo...ducts_id=29&osCsid=bonqeaqii841kiosm0urqhbha6
this is for a 66cc engine.and i am confused and have some questions
-can i put this on my single gear beach cruiser?
-will it incress the performance at all
-is it reletivly easy to put on?
-does it have any advatages over just a single gear?( i counted 6 gears in the vidios of people who have put this kit on there bike)
it would be great if someone could clairify a bit.
Thank you!
jman231994
Australia
Is the engine sprocket normally on the bike gear side? If it is, all the kit does is let you use a freewheel front sprocket. If your engine uses bike chain normally then all you realistically have to do is run chain directly to a bike cassette on the rear wheel. Might need another gear reduction though.
It should let you either maintain or increase your top speed, as well as giving you heaps better hill climbing ability if its geared right. Imagine riding a bike with multiple gears, you have the ability to maintain pedal speed whilst generating more torque by changing down gears. And to increase speed with the same pedal speed by changing up. Will do exactly the same for your engine.
Whether it will fit in a beach cruiser....I have no idea. Does it only have a single speed sprocket on the wheel?
