Spark Plug Again
MancoGX390
Just tinkering...
Devon, England
Hi there all, just pulled the spark plug out of my GX390 and realised that its changed colour from last time i checked, is it a good colour?
I'd say it's either a hot plug (and you should get a different plug) or it's running a bit lean.
since I believe I read BPR5ES either try a BPR6ES or play with your jetting a little ;)
I don't think I'd use "dangerous" to describe the plug..
I'd say it's not optimal :D
running too hot or too lean will affect the longevity of your engine (and the performance a little)
but again I'd say you're just a bit on the lean(or hot) side, pretty close to an okay reading..
the cooler plug might be enough to have a perfect plug reading *shrugs*
And it'll only add to the lifespan of the engine itself, so 2 bucks to try ;)
MancoGX390
Just tinkering...
Devon, England
Thanks again Sid! Will get a new BPR6ES plug!
