I thought I attached the picture, anyways I attached it now.A coin? Sandwich? Gremlin? Perhaps you should post a picture.
Attached it.Accidentally didn't get the picture all the way here! Get us a picture and someone will have an answer. Don't worry, most of us have had a picture not post.
Idk lol, thats why I'm asking.Charging coil?
Probably a janky points condenser part, I've never seen one wrapped in cloth before... Or it's an internal charging coil. We have to remember this engine has E-start, so it could have a stronger charging system. I think we have to bring in @karl for this one.Charging coil?
I removed the e-start completley, so can i remove it? And also the wire wasn't attached to anything.Probably a janky points condenser part, I've never seen one wrapped in cloth before... Or it's an internal charging coil. We have to remember this engine has E-start, so it could have a stronger charging system. I think we have to bring in @karl for this one.
No. This is what provides the electricity for your spark plug to function. I would suggest checking out a video of how a basic four-cycle engine works so you understand the principle. It's a whole lot easier to fix something like this when you understand it.I removed the e-start completley, so can i remove it? And also the wire wasn't attached to anything.
Well, it ain't attached to anything so how does it power the spark plug?No. This is what provides the electricity for your spark plug to function. I would suggest checking out a video of how a basic four-cycle engine works so you understand the principle. It's a whole lot easier to fix something like this when you understand it.
Well that's one of you problems. Could I have a complete picture of the flywheel side?Well, it ain't attached to anything so how does it power the spark plug?
If it's part of a points-condenser it could be, my Clinton was set up the way.It's not the coil I don't think. Not if it's under/behind the flywheel. But I could be wrong, it would be the 9 millionth time.
The inside u mean?Well that's one of you problems. Could I have a complete picture of the flywheel side?
Nope, just the whole engine on the flywheel side. But the inside of the flywheel would help as well.The inside u mean?
So since I removed the e-start, can I remove this coil?It's a charge coil for electric start engines. Pretty sure one is used to charge the battery and two are used to charge the battery on a kart with headlights.
Charging Coil Assembly | Electrical | GoPowerSports
Charging Coil Assembly, Mini/ Mid. Go kart, mini bike & UTV parts specialists at GoPowerSports.www.gopowersports.com
