Something I've never heard before
redsox985
PA
So, tonight, my friend and I were spinning around the yard on my kart and had the weirdest thing happen. He was on a slight slope and gave it gas to get moving. Then, we both heard what I can best describe as "THWA-FOOMP" and the motor cut off instantly. There was no sputtering, spurting, dying, or any other noise. My first thought was something blew internally and that caused it to stop instantly but I gave that a second's thought and decided that an internal failure would have made a heck of a lot of noise. To put this to rest somewhat, we pulled the plug and the muffler and looked inside and it all looked good. I checked all of the kill wires and the kill switch position immediately and they were all good and set to run. It had plenty of fuel. I have my low oil disconnected and the rest of the motor is totally stock. After a quick once over, we confirmed I had it under warranty still and pulled the cord. It fired right up and ran fine for the rest of our bashing.
So, does anyone know what might have happened to kill the engine instantly with a sound like a big POOF of air?
Rustydog2010
NZ Nutta :|
New Zealand
I had the same on a motorbike, was racing around on it for maybe 5-10minutes. Came back to the house and stalled it, so I went to kick it over again, and it made a noise almost like a single shot of a .50 cal gun, you could hear it echo throughout the valley! It scared the sh!t out of me, gave it a quick once over, then kicked it over again and it ran like a charm. I think I saw a slight bit of smoke coming from the coil. Don't know what, or how, but still runs smooth today.
Jeremy.
Cam
Nz Petrolhead
Whangarei, New Zealand
I think you may have had a case called shotgunning, we used to do it down hills and stuff, its when your ignition cuts for a bit and you pump the gas pedal a bit ( or a lot : D ) and the cylinder and exhaust pipe get filled with unburnt petrol, then when the ignition comes back on, or you flick it back on the next stroke that fires explodes the mixture and it makes one hell of a whoosh ka boom, like a shotgun. usually stalls engine, and it doesnt seem to be that good for it as well : P
fowler
Bullsbrook West Aus
yeah
could short in the ignition system
i washed the forklift at work and when i wanted to start it up it did as discribed above
took the distribution cap off sprayed in some crc and off we go
Rustydog2010
NZ Nutta :|
New Zealand
Its 'key-banging' haha ;)
Frive down the road in a car with a carburetor'd engine. Turn the car off while still rolling, pump the accelerator, then crank it over again. The resulting noise should be a loud backfiring noise.
Jeremy.
sexyvicta
^did that the other day for the first time since i was like 16 and blew a massive hole in my muffler:thumbsup:
redsox985
PA
It's wasn't loud at all though. It was just like a big poof of air. From about 50' away, I barely heard it. I heard a very small puff of air, but mostly just the motor cutting off instantly.
redsox985
PA
Ahh... then that'd technically fall under the classification of an engine fart or quite possibly a queef if you'd given your kart a girls name and surgically removed the governor shaft :D
I haven't named it and the gov. is still intact, but I'll file it under "kart queef". Has anyone heard of this though? I've heard backfires and other sounds an engine shouldn't make. My friend who was driving it at the time has been riding motorcross for about 10 years now and said he's never heard an engine do that. It didn't sputter or die off like an engine does when you hit the kill, it just came to an instant stop. But nothing inside blew up causing this. I'm baffled.
