Some things really baffle me!
MatthewD
Northern Ireland (UK)
Hello all,
As most of you know, I have build a modified kart with a modded Honda GX160. I've had no problems whatsoever with the engine, until now.
The motor has suddenly lost power and my governed drifter can overtake it. Now it won't rev under load. Took carb apart and cleaned it. Put it back on, fired it up and same problem. Took it apart and dirt in jet again. I kept doing this and doing this and then replace the tank with another one and cleaned fuel line and carb. Same problem.
Where can the dirt be coming from and how does it get to the jet so quickly?
Hate to say it, but is the "fresh" gas you are putting in, fresh and clean. Like no crap in the bottom of the Jerry can.
Blakey
Time Traveler
Green Bay, Wisconsin
More filter (cowbell)
Yeah it should be. I have a filler that I use to put the gas into the tank which filters it.
Put a in-line filter in there if you can, its great insurance against annoyances. I have also seen old fuel lines dissolve and cause problems.
Blakey
MatthewD
Update,
I've heard of boiling carbs in lemon juice, but I didn't have any so I used water and vinegar instead. I cleaned tank, fuel line and carb. Put her back together and now she'll run off load (rear axle up on a stand). Further investigating shows that the gaskets are gone so I ordered up a set. Hope it will fix it.
Poboy kartman
Senior Moments Member
White Settlement Texas
Update,
Good idea Matt.....acetic acid vs. citric acid....but same basic idea....
It's possible however, that the solids in the lemon juice actually perform a mild scrubbing action.....enhancing the cleansing during boiling....
But I'll bet a few members around here will be giving vinegar a try in the future! !!!!!!
Poboy kartman
I use have used vinegar for removing bluing and rust from gun barrels/parts.
Ketchup can be used as well.
Works better than lemon juice IMO.
Ketchup for karberators????? Or does catsup work better on carburetors???:lolgoku:
That's a little hard for me to fathom.....gun parts maybe....but how do you clean a carb with ketchup?
