Russell ATV
I thought I would post some builds I have done over the years, along with a "what I learned" summary. I built a fair amount of crap, but with each build, I got better.
In general, these builds were experiments in lightweight vehicles with suspensions. Here we go:
First kart, the Leaf Spring Steel, Tadpool Quad
Got to start somewhere. I laugh thinking about this kart, man did I get a few hundred things wrong. First, without any real supply of steel, I used galvanized tubing. I was careful to weld outside and avoid the gases, but this stuff is week. Next, note the plastic wheels. Lots of good deals on Surplus Center, just the wrong wheel for the job. The rear wheels had thick plastic barrels that I used a dowel pin to connect it to the 3/4" shaft. Nothing more fun that ripping off a rear wheel at 35 MPH with that much power (6.5HP clone)
I made the rear section only wide enough for the motor. Not the best solution for cornering. Also, the front wheel spindles had no kingpin angle or camber. It was a white knuckle ride with no centering effect. The seat was a small child's school chair. It was remarkably comfortable.
The leaf spring material was like 3/8" thick, and did not provide much spring. It was also very brittle and difficult to work with.
Russ
Russ
