some coupling frozen on to crank.
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I'm doing a neighbor a favor and changing the pump on his 5 HP Honda since he burnt the old one out by accident. Now, I found a 3000 psi pump which is an upgrade from his 2400 psi for $96 on eBay. The gun and hose have psi limits which are higher than the pump produces, so I guess we're good there. The problem is that after I removed the old pump, there's this spacer or some kind on the crank which uses a hex key to screw in to the keyway. After getting assitance from my dad (which is not often), I realized the screw is obviously frozen being the fact that the unit's from 2002, but looks great. I can't make him purchase a new pump which I'm uncertain if it will fit with the spacer in the way. The old pump is a dual opposing cylinder kind where the shaft of the pump is bolted on to the shft of the engine and uses a shroud to cover it. So, turning the screw with the standard hex keys we have, with pliers, isn't working. Ra out of wd40 til tomorrow, so for the time, I poured two stroke oil on the problem and ill let it sit. I doubt that'll help, soo.. What would DIYgokarts do?
Edit: after uploading it thru tinypic, I realized my st00pid phone uploaded it afterall.. smh.
fowler
Bullsbrook West Aus
Well deisel is good for soaking parts
Or CRC
I think u guys call it on blaster
Iv never found a use for wd40 it's highly overrated
If u have a small enough punch put it inside the set screw and give it a fair whack that will jar the threads and helps a bit
Otherwise heat is good
Last resort is to cut the spacer off
Or pull it off
kendelrk
redneck engineer
westland michigan
Or CRC
Or pull it off
we call it pb blaster, but how big is the hex bolt, and how deep is the opening? an impact driver with a hex bit would take it out fairly easily i would think
Brandon1023
needs an oil change
Folwer, you were on point. I got $2 worth of Diesel, let it soak for maybe 30 minutes, took a butane torch-style cigarette lighter and heated the screw for about 20 seconds, and gave it a turn with the hex key. It took some force, but it spun right out once the freeze was loosened.
Now that its off, I can see that the crankshaft is probably an inch or so to work with. What's this garbage? I have an identical pressure washer which ill pull the pump off to see if it has the coupling, because I don't see this 1" long shaft grabbing on to a pump's keystock.
