Solenoid, starter, and alternator wiring?
Kaptain Krunch
Pro Junk Collector
vermont
I'm completely redoing my wiring on my off-road mower, the last person did a hackjob on the whole thing, and all the wires are rusted out. So heres my question, how do i wire everything up? its got a duel coil alternator, electric start and a 3 pole solenoid.
The way i think it should go is
Positive from batt to one of the large solenoid poles
negative from batt to ground
small pole to push button, other wire from push button to Pos batt terminal
other large pole on solenoid to starter
positive wire off of alternator to positive pole on batt (there is a red and black wire off of the alternator, im guessing red is pos)
Is that even close to right? also i have a amp meter, how would i wire that in there?
solenoid
2 wires from alternator
theres also a yellow wire coming from the governor linkage area, not sure what its for, does anyone know?
EagleTalons
Master JB Welder
Forsyth, Montana
well for the solenoid it would go.
battery -big pole - other big pole - starter
Small pole - push button - ground or pos...can't remember =P
Stator is
4amp side - battery
high amp side - lights and amp meter
Yellow wire is the kill switch
Kaptain Krunch
Pro Junk Collector
vermont
Stator is
4amp side - battery
Alright, i was close (im guessing push button to pos).
Anyway to tell which wire on the stator is the charging wire? un guessing its the red one but have no idea, currently the engine isnt running so i cant check...
