Swabbster
- Messages
- 439
- Reaction score
- 0
hey guys i have a old 400 snowmobile and it has a single carb without a choke, the only way i can get it started is by squirting gas down the carb, does it need a primer bulb to push fuel through the jets to prime it, it has 2 fuel lines as well so not sure, i will be installing a air filter so i wont be able to get to the inlet, not sure, im thinking about putting a different carb on it, or upgrading to dual carbs, i may be using it for a buggy, and if not keep it and use it for a go kart someday,
