You're going to need the CVT components from the snowmobile- both the drive and driven units. You will need to mount the driven unit to a jackshaft spaced exactly as far away as it was on the snowmobile (unless you want major headaches trying to find the right belt size). On that same jackshaft you will mount a sprocket, which is connected to your rear axle via a chain.
