Snowmobile clutch on axle?
r97
Measure twice cut once
Massachusetts, USA
Proper gearing will increase performance. Besides, a jack-shaft is not that complicated nor is it that expensive (one would likely be included with the snowmobile). Also keep in mind the driven clutch may not have a handy 1" bore with a 1/4" key-way.
... Which is why the best method I have seen yet is to scoop the whole enchilada off the sled- including the cradle.
"Proper gearing will increase performance" is an understatement, mate! If the gearing is too far out, you won't move! (Or, you'll hit a whopping 0.00001 MPH at 10K RPM!)
