Smoking Clutch
Bernie12
Hi all. I am new to the forum and I hope someone can help me with my problem. I got a used Yerf Dog go kart and I have converted it from a belt torque convertor drive to a direct centrifugal clutch chain drive. OK, here's the problem. When my little guy took it out for its maiden run, the centrifugal clutch started smoking and getting hot, especially when he was going up hill and then it wouldn't go at all until I gave it a shove and it was on level ground. I am running a 10 tooth clutch driving a 60 tooth drive sprocket, so I know through a little research that that is the proper gearing. The rear tires are direct drive (both go when clutch is engaged) and the size of the rears is:
18 x 9.50 - 8. I believe that the problem is that the clutch is getting over loaded due to the bigger rear tires. Does this sound right? If I change to a smaller rear tire, what do any of you suggest that I go to? Can I stay with the same 8" wheel, or do I need to change the wheels to?
And yes I know, that changing from a belt drive torque convertor system to a direct chain drive isn't really the way to go, but I feel better with the chain drive and it's too late to go back.
Sorry for all the questions.
Hope someone out there can help out.
Thanks.
Russ2251
AZUSA:Powered by LAWN-BOY
A complete change over to a centrifugal clutch driven system will end up being more expensive than simply repairing or replacing the TC.
From the sound of your description your new clutch is already ruined.
Russ2251
From gokartsupply.com:
"Clutch warranty: How long will the clutch last? If it's installed on the engine crankshaft properly, without using the "magic hammer" to pound it on the shaft, using the right length key (half inch) and observing all the hints that are pointed out in this article, a clutch should last several years. But, if it's improperly installed, driven in abusive conditions (sand, steep terrain, excessive weight in the kart or rear tires taller than 15 inches), the clutch might only last 20 minutes. If the shoes are blued don't bother sending the clutch back for a warranty replacement. Heat damage is not a factory defect, it wasn't sold with blued shoes. If the clutch is abused, the tell tale signs are easy to spot. Go Karts with rear tires taller than 15 inches or an engine larger than 8 horsepower require a torque converter. If your kart has rear rims larger than 6 inches you'll have to install a Torque Converter that uses a belt and a chain. The last number of the tire size is the rim size."
Bernie12
Thanks Russ, that's the answer I was looking for. I thought maybe the tires were to big and thus a drag on the clutch. Actually, converting from torque convertor to direct drive was not as expensive as you would think and it was easy to do. I am somewhat mechanically inclined, but not so much with go karts. Parents wouldn't let me have one when I was young, thought they were too dangerous, LOL. Guess I have to live dangerously through my 11 year old.
What would you suggest as far as tire size then? I was thinking maybe 15x6.00.6.
Russ2251
It's a matter of personal preference.
That tire size will yield about 14.8" diameter. You will still have to purchase a larger driven sprocket.
I prefer not to go over 11" for tire diameter and I use 70 tooth driven sprockets.
My clutches never overheat.
