Small Engine Performance Modifications - The Ultimate Guide
KartFab
Dallas, TX
Engine Mods & Performance Parts
This guide will go over what it takes to modify a small industrial 4-stroke engine (Predator 212cc) to rev higher and have more torque (partially answering age old question -'How do I make my Go Kart Faster?' It goes over the basics. There are ALWAYS trade-offs to consider before purchasing and installing any performance part.
This guide will be for the average DIY person looking to get cheap/minor upgrades as well as some of the high end upgrades you see engine builders implementing on 'builder's prepared' engines. This guide will not show you how to install anything. It is only an introduction to performance upgrades. You have to do the research, and you are the decision maker. So let's start with the very basics. If you cut corners, you can ruin your engine so I have broken it down into suggested stages.
Stage 1: Intake, Exhaust, Jet -The best bang for your buck.
Cost: Under $100. Benefit: flow, significant horsepower gains
Out of the box, small engines are very restrictive to air flow. An engine needs to be able to breathe IN and OUT with less resistance. Adding a high flow air filter, and intake adaptor to fit the air filter will allow the engine to breathe IN easier. This is bolt on upgrade that requires no special tools. Half of the problem is taken care of, now the engine needs to breathe out.
A high flow exhaust header is what to get. Any header will modify your power band, but the 'best' one to get is an open '3 stage header' which keeps exhaust flow high for low end torque, and helps with flow on the top end of the RPM range. Headers are open (loud), but can have an aftermarket performance muffler clamped to them if you do not want to make your neighbors angry, of if you enjoy your ability to hear. When you do this type of upgrade, you will likely need to re-jet your carburetor so it will deliver more fuel with the added air coming into the engine. A nice upgrade to do when jetting is to get an emulsion tube for a stronger fuel signal at the carburetor.
Stage 2: Remove Governor - Unlock the RPM limit.
Cost: Free (governor removal) linkage kit $6-$30 Benefit: 3600 RPM threshold removed.
The governor has two main functions. 1) keep the engine's RPM limit around 3600. 2) opens throttle when starting for a hassle free start. Removing the governor will let the engine rev to a higher RPM, and sometimes prevents the engine from being cold started unless you manually open the throttle butterfly when pulling the starter cord. You need a socket set and basic hand tools to remove the governor. Some people also remove the governor arm and replace it with a bolt to seal the engine case. After removing the governor, you must either slightly modify the throttle linkage, or install a direct throttle linkage kit.
Warning: Once the governor is removed, you have eliminated a major safety mechanism that will keep your engine from wearing out prematurely, or throwing the connecting rod. There is still a debate about at what RPM this will happen, with real world experiences vs. safety factors coming into play. You can probably get away with staying in the 4K rpm range... but all bets are off, do it at your own risk. In spite of the debate, everyone agrees that the BEST practice is to get a billet connecting rod and flywheel so you don't have to experience catastrophic engine failure, or worse - serious injuries (don't freak out - usually the rod just punches a nice hole in the block, effectively ruining what you worked so hard to upgrade).
Stage 3: Billet Aluminum Connecting Rod & Flywheel - Safely run high RPM.
Cost: billet rod $70, billet flywheel $110 Benefit: engine doesn't blow up.
This is the insurance policy I HIGHLY RECOMMEND having against engine failure once you remove the governor. A quality billet aluminum connecting rod can safely operate even above 10K RPM's (not that you will ever reach this figure). Get a stock length billet aluminum connecting rod. For highly advanced builders, a slightly longer connecting rod, an d/or combination of performance piston and increased stroke crankshaft to build a 'stroker' engine is used. For the rest of us, just get a stock billet aluminum rod. Again, there is debate on whether you can rev to X RPM's safely with a rod, but the stock cast iron flywheel. Don't fall into the trap of thinking you will be 'safe'. Why would you risk your health, time, and money by cutting corners? In my mind, a connecting rod and billet aluminum flywheel upgrade need to happen at the same time. What is worse than a thrown rod punching a hole in your block? A shattering flywheel flinging high speed shrapnel everywhere with you being somewhere in the everywhere part. Alternatively, you can get a PVL flywheel for a little less $$, and have the protection from it shattering.
Stage 4: Camshaft & Springs- Help the flow, and target your peak power RPM band.
Cost: camshaft $40-$100 springs $6-$30 Benefit: power band shift and overall hp improvement
A) Cams One of the best ways to really boost your performance, and fully take advantage of all the other performance upgrades you have done so far. When you purchase a performance camshaft, the lobes on the cam alter lift and duration of the valves. In other words, they help with flow, and let the air/fuel mixture in/and exhaust out at certain times.
But which one? There are so many to choose from a.k.a. so many wrong ones to get. So which one? There is no magic bullet, and cams always have tradeoffs. A very relevant question is this: "Where do I want my peak performance?" You will have to decide if it is going to be low end torque, or high end torque, keeping in mind that low end torque cams cant rev high, and high revving cams can reduce your engines performance below stock at anything below the RPM range you will be driving your go kart in. So how would you like your 6.5 hp engine to have 4 hp when driving your go kart? Blindly buy the highest revving cam and you will find out the hard way.
I personally would suggest getting a 'mild' cam that will rob limited performance from the low end, and provide peak performance mid range, and still be able to rev to 6000 or 7000 RPM. If you don't anticipate revving to high rpm, it might be a great idea to get a winch cam, or torque cam for riding a go kart around. Watch out for cams that may require 'clearancing' as these are for advanced builders.
B) Valve Springs You must decide which set of valve springs to use based on your target power band, AND the camshaft. Camshaft's typically have a 'cam card' that recommends what to set your timing to, among other things. You can use your cam card's specs to find out which springs to get.
Valve springs are two faced. They work for you, and against you. Although springs are simple, the combinations available are numerous, just like camshaft choices. A rule for springs is that the heavier the spring (compression resistance), the more horsepower they will rob. That's right, choose the wrong spring set and you actually lose performance with zero gains anywhere. Valve springs are designed to keep the valve train from the cam to the valve seats in sync. The cam(through the valve train) opens the valves, and the springs close the valves through their compression resistance. When you rev above a certain RPM (about 5500 for most stock 4 stroke engines), the springs cannot close the valves in time and/or the valves actually bounce on the valve seats -this is what is called valve float. To prevent valve float, a spring with more compression resistance is installed, which prevents floating until a higher RPM is reached. The higher spring resistance internally reduces the power output at the crankshaft.
You need to select a spring set that will experience valve float just above your maximum RPM. You do this to mitigate parasitic drag. The nice benefit of choosing a lower lb rating valve spring, is that leading up to valve float, the spring's energy has the least amount of parasitic drag, which translates into more power at the crank. So the moral of the story is don't get dual valve springs for a 8K revving engine, and put them on an engine that can only rev to 6k rpm with the cam and other performance mods, it just ruins engine performance, the irony.
Conclusion
There are always limits. There are always trade-offs. Understanding why parts do what they do, and what you want out of your engine, as well as the limitations they all have will help you answer your own questions. This guide will probably give you more questions than answers, so please, if you are serious about performance mods and want to upgrade your engine, call a go kart race shop and talk to their engine builder for expert advice for your situation.
If you want to get parts, just google "your engine+insert name of part" then hit enter, crazy i know. Here are a few places to get the parts for a 212cc predator though
GoPowerSports - high flow intake/exhaust kit
Arc Racing - billet flywheel and connecting rods
DynoCams - camshafts/springs
or any other place that sells this stuff, google really is your friend, and you can probably find tons of places selling the same stuff.
KartFab
Dallas, TX
Other/Advanced Building Techniques -List of crap I can't/won't explain yet -know that it exists, and that you can look into some of it for small and large gains. Not necessarily feasible for some DIY people that like bolt on, easy, or inexpensive solutions.
lapping valves
reading spark plugs
engine break in procedure
dyno testing
bench flow testing
performance carbs, bored vs performance
sparkplug indexing,
larger valves
Increasing compression - compression ratios and their limits
a) through spark plugs
b) through milling
c) smaller heads
d) pull start issues, need for starter
Over boring, ring installation, file to fit rings.
rockers vs roller rockers, high RPM applications
port and polish
methanol vs pump gas and jetting/timing adjustments needed
what oil to use - the thinner the better?
sidecover & block reinforcement
stroker build
Clearancing
checking clearance from the piston,
clearancing cams, valves, and other parts
balancing engine after part installation and clearances are complete.
I've read that valve lash can be set as low as zero if set when engine is cold. Haven't tried it, but, specs say 0.004 and some people say .002 intake and .003 exhaust.
Is decreasing valve lash essentially the same as increasing the lift height on the lobes of the cams.
I realize that too low of a lash setting may not allow the valves to close properly, especially with stock springs
---------- Post added at 08:22 AM ---------- Previous post was at 08:07 AM ----------
Engine Mods & Performance Parts. Stage 2: Remove Governor - Unlock the RPM limit.
Watch a dozen videos on how to do this then tried to completely remove the gear and all connections. It was tough trying to fight the clip holding the gear on.
The 13th video I watched (AFTER I DID IT) showed a very easy method of removing the flywheel and punching out the entire shaft that the plastic governor gear spins on.
Tapped for 1/4 -20 bolt with redlocktite
This might make it easier for others in the future
Poboy kartman
Senior Moments Member
White Settlement Texas
Decreasing valve lash not only slightly increases lift..it adds duration which both help to increase volume slightly...which translates to better performance.
Need Help choosing a Cam
A) Cams You will have to decide if it is going to be low end torque, or high end torque, keeping in mind that low end torque cams cant rev high, and high revving cams can reduce your engines performance below stock at anything below the RPM range you will be driving your go kart in. So how would you like your 6.5 hp engine to have 4 hp when driving your go kart? Blindly buy the highest revving cam and you will find out the hard way.
looking for cam for 18lb springs and stock lifters, valves, rockers,....
My buggy with TC can be geared to 7.5 : 1 (20.25 : 1 at 2300rpm)with 16" Tires. With stock springs (10.8 lb I think) and stock cam, I'll probably top out around low 30's around 5400 rpm. Would like to into the 40's with this gearing and wheel size. That means 7000 rpm
(NOT CURRENTLY GEARED THIS WAY)
looking at this cam (7000 rpm max) https://www.ombwarehouse.com/CS-Grind-Clone-Core-Cam-Clone-and-Predator-Hemi.html?category_id=1641
lift is increased (0.03 "- 0.04") so I'm worried about needing new parts of valve system. Want to keep most of it stock
before reading this I was looking at this 7000+ RPM cam
https://www.ombwarehouse.com/MOD2-Grind-Clone-Core-Cam.html?category_id=1641
less lift, but more duration and higher RPM max.
Will they both work with stock parts (besides springs, flywheel, connecting rod)?
Do you think I can get away with the MOD2 (7000+ RPM) because of relatively higher gear ratio (7.5 : 1) vs 6.0 : 1 stock and smaller tires (16") vs 20" stock
and still have significantly better than stock (meaning 6:1 and 20's) low end power??????
Poboy kartman
I've seen people suggest valve springs when you do remove the governor.
RIGHHHHHT! Yeah.....worst advice ever. DO NOT CHANGE VALVE SPRINGS UNLESS YOU UPGRADE THE CONROD.
Perhaps I need to clarify: DO NOT CHANGE VALVE SPRINGS UNLESS YOU UPGRADE TO BILLET CONNECTING ROD!!!
Removing governor and leaving everything else alone is fine!
And ...you DON'T need a billet flywheel!
I've never heard of a flywheel exploding because of high rpms unless if it was very poor quality, or was off balance from dropping or whatever. But if you can stick with using the stock flywheel then it's not worth spending nearly $200 on a flywheel for a cheap engine. With my count on how expensive this is getting if someone went to stage 4 they are about $700 in. One could buy a Briggs Animal for the cost of a modded Predator. I think as far as most people will go is jetted carb/aftermarket, intake, exhaust and port/polish, and maybe adjusting valve lash as well as spark plug gap. These engines came out 4 or 5 years ago is there anyone whose had one that long with modded and has put a good number of trouble free hours on it? Stock these engines should like they can last...but how does modded hold up over time?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Reducing weight isn't necessarily something you want to do though.
Partially Right.
But in this case removing "Flywheel weight" Which is "Rotating mass"
is a good thing. It takes HP to spin that 5 pound flywheel, So having a 3 pound flywheel will increase usable HP from the engine.
Jrgunn5150
Rudderless
Partially Right.
I don't know about go karts, so I may be wrong, but in my full sized vehicles, particularly my 4 cylinder Jeep and 4 cylinder Toyota, adding a heavier flywheel, (since a flywheel is designed to store inertia), kept them chugging and lugging along at slow speeds without slipping the clutch so much.
In my mind, I would imagine a more off-road oriented kart, would benefit from the same practice.
