mark123
I have a 6.5hp electric start clone and added a second charging coil so there are 2 under the flywheel now. This engine came with a small diode and the coil I took from a honda 9hp had a small rectifier. Should I keep both independent of each other and then splice them together after their diode/rectifier or could I splice the 2 coils (ac voltage) together and then run them both through the honda rectifier and leave the tiny diode out of the picture.
