slow take off
1sttower
I had a 5hp b&s that wore out and swapped for 6.5 honda clone. now it has no take off power. wont pull at all on incline. Once going seems fine. do I need to change the sprocket. 60t 145/70-6 same as with old engine the worked fine. sorry noob here anything else i need to check also?
1sttower
hard to remember long time since running but i believe the clutch may have been changed since engine swap.
I bet it has. If only the engine was swapped, performance should be similar. Either the clutch was replaced with a dissimilar unit, or something in the driveline's seized up. Does the kart freewheel okay?
1sttower
works fine on stands and once rolling but engine seems to bogg down with even light rider on take off and wont go on even small incline only flat able to push easy. having to push while son gives gas to get up small hill in yard but will easily roll down without giving any gas.
That really does make me think something changed other than the engine. Perhaps it used to have a CVT, and a simple clutch was put on. Maybe the rear tires were changed to something a fair bit larger than original. If the original clutch was a centrifugal clutch and it got changed out for a new one, perhaps the new one has several more teeth on it. Or the new one is shot.
