sled guys check this out...
Kaptain Krunch
Pro Junk Collector
vermont
nope, its a two. for $20 i'd go for it. if ths skis and solid, and the track is decent you could probably get $75 for the two on ebay alone. Wont be an amazing kart engine, but its a step up from any industrial engine.
Pellethuntr2
Machinist
NY
there's pretty much nothing left but an engine...im wanting to either put it on my kart or maybe my bobber street bike...question for you guys though...I was reading through the "snowmobile how to" sticky and it says that you need a jackshaft...why is that???
sideways
Unfinished projects king.
Perth, Western Australia
Because of the way the transmission it set up, think of it more as a shaft for mounting the rear part of the transmission on.
Thanks
Hayden
Kaptain Krunch
Pro Junk Collector
vermont
The secondary cannot mount directly onto the axle, so you must mount it on a jackshaft. Infact you may end up needing a double jackshaft setup to get the proper reduction.
Pellethuntr2
Machinist
NY
wait how come it can't mount directly??? doesn't the snowmobile you a basic cent clutch design???
Pellethuntr2
Machinist
NY
ok gotcha so basically it's got a toque converter on it so it will need a jackshaft to run the secondary part of that...
