this is a bit of a rant, so I'm just going to warn you all. input is welcome however.
Okay, everyone who tells someone that a snowmobile engine will not work/ run properly in warm weather needs to get their facts straight. I just want to point out a few common errors in thought, and correct them.
Stupid comment #1 "You could use a sled engine, but its going to over heat." FALSE! ever heard of turf drags? I've even attended sled drags on pavement in the heat of summer, no problems.
#2 "Those engines are tuned for cold weather, so they wont run worth a **** in the summer." FALSE worst thing that's going to happen, is its going to need the mix screw adjusted to run a little richer/leaner, after that it will perform just as good as a Motorcycle engine.
#3 "Your only going to be able to use a liquid cooled motor, cause everything else will run way to hot." FALSE a liquid cooled may run a "bit" cooler, but will run just as good as a fan, or even air cooled engine. Hogs run just great don't they? the answer is yes, yes they do.
#4 (and final) "Don't use anything bigger than a 340cc or it'll burn up." WTF ARE YOU ON? if i need to explain this, after all that, you need your head examined.
final thoughts: what have we hopefully learned here? I hope that you wont hesitate to use a sled motor now, as long as you can fit it, and it wont be too much for you or the frame to handle, do it, you wont regret it. By the way, this isn't written out of ignorance, here, in Michigan I have either built, or helped to build at least 20 sled engine powered carts. all of them run great, and will continue to run great with proper maintenance.
If you need more proof, I might be tempted to track some of these carts down, and tape them. Or you can just look up summer sled drag racing its pretty common.
If I've missed something, please feel free to post it.
