Sled engine mounting?
joejoeguns
ya thats my bike
n.w. indiana
I'm converting a golf cart to a sled engine.I made up a custom motor mount/jackshaft setup that is basicly a complete drive system that I will mount to the swing arm of the golf cart. My question is should I rubber mount or solid mount my drive unit.The motor is a 340 rated at only 30 HP.
Kaptain Krunch
Pro Junk Collector
vermont
I would use the rubber mounts that were used on the sled, Just make sure you put a support between the block and the jackshaft bearing so it doesnt twist the motor mount under hard acceleration. However, a solid mount wouldnt be an issue either.
joejoeguns
ya thats my bike
n.w. indiana
I was just wondering if any one has had an issue with solid mounting a sled engine. I fabbed a jack-shaft assembly that incorperates a motor mounting plate so the whole power train drive unit is single assembly ,I will be mounting this to the swing arm.
I would rather solid mount it because I'll be running a chain to a live axle and I'm afraid the torque will pull too much on the rubber mounts.
I've had plenty of sleds and they all have rubber mounts, after doing some research I see lots of guys converting to solid mounts.I was just worried the vibrations could crack the block.I'll put up a pic after I get back to the shop and get one so you guys can see what I got going.
fowler
Bullsbrook West Aus
U won't crack the block
The vibrations are going to crack the frame before they crack the block
Look how all motor bikes are
Both on and off road
If the rubber is too thick then there will be an ever changing chain tension causing issues
If the mounts are thin enough to eliminate the chain issues then they are too thin to stop vibration Thursday the frame
Swabbster
Take a thick mud flap from a big rig or something, you could make a big square with the bolt holes or some smaller ones for each bolt, what kind of motor is it, I just bought a 340 rupp/kohler
joejoeguns
ya thats my bike
n.w. indiana
Heres the jackshaft/motor mount I made up.Doing it this way I have no alinement issues with the belt.The unit is basicly a bolt in drive unit, just mount to the swing arm and hook up the drive chain.
I'll put up some pics with the motor and driven hooked up later.Motors at the house and the rest is at the shop.
Swabbster
Looks good, could use a lot more bracing tho, once that powerful engine starts torquing over you may bend the mount, also by no alignment issues, does that mean your pulleys are lined up belt wise and or length wise, (belt not to tight but not to lose)? Also depending on how old it is, the clutch may be really wired, shift way to quick/way to late
joejoeguns
ya thats my bike
n.w. indiana
I thought about that.I'll keep an eye on it when I test run it.It's all made of 1/4 inch plate and there is no latteral load on the shafts,so it should be ok.If not its a easy job to beef it up.here it is all mocked up.I went ahead and rubber mounted it,just because I had the stuff and what could it hurt.
joejoeguns
ya thats my bike
n.w. indiana
Single carb,It's a 340 out of a 1980 yamaha enticer.It's only rated at 30 hp but should move the cart just fine.I've got it geared 9.5 to 1 on the low end ending up at 6.5 to 1 after shift out. I'm hoping to see 40 to 50 mph.The clutch is set to engage at 3000 and max hp is reached at 6800.The hard work is done now comes a boat load of little stuff.
joejoeguns
ya thats my bike
n.w. indiana
It needs to "float" a little side to side,It will find its "home" when under load.This is to compensate for any slight alignment issues or torque flex.
