size 50 chain
mirnes
hey so i have a size 50 chain but I don’t know what kind of clutch to get for it. I have bought three clutches in the past none of them have worked, so please if you know, tell me what size clutch I need and what website to get it on? I have a size 50 sprocket I just don’t know if I can put that in a new clutch if I can can someone send me a tutorial video on how to do it.
mirnes
i thought of that but if yku want you can search this up i have a kandi sufari hauler and the only chain it can take is 50
Can we get a few specs for the vehicle? Tire size, a picture of it, and sprocket tooth number.
mirnes
its a kandi sufari hauler and where do i find the sprocket tooth number
mirnes
There are no clutches or CVTs for a 50 chain unless you go industrial $$$$.
Can we see a picture of your kart, axle and engine so we can try to help you?
yes but i will send it tomorrow sonce its 12:30 rn ty and whats a industrial
  • Like
Reactions: G.W
mirnes
G.W
Nyssa Oregon
You can take the axle out and switch the axle sprocket to 40 chain and use a 40 chain clutch.
Okay, I few things. That kart is too large for a clutch, it needs a CVT. Is the engine mounted on wood? A 32 tooth Unfortunately won't get you the correct gear ratio for that size tire, you need more teeth. While you're at it converting to #40 chain wouldn't be a bad idea. From the angle it looks as though the engine is mounted on wood alone, is that the case? @mirnes
