Simple clutch question
MakDad
I'm new to go karting. Just bought a used "fun kart" for my kids to play around with and already ran into a bad clutch.
The thing was very rusty and the kart wants to run away at half choke. From what I understand it's a bad clutch.
Now for the question: The little sprocket on the clutch has 11 teeth on it. All I see everywhere is either 10 tooth or 12 tooth and the 11 tooth seem to be much more expensive compared to 10 or 12.
Do I have to match my old clutch with tooth # or can I go with 10 or 12 ? What problems will I run into if I do go one up or down ?
Any help appreciated.
minibiker
USA
what motor is it on? What kind of chain? 35 pitch are usually 12 tooth an 41 pitch is 10 teeth. Try putting some oil on the bushing in the clutch . The one that slides over the crankshaft that may fix your clutch
Poboy kartman
Senior Moments Member
White Settlement Texas
Thanks. minibiker.....this one would actually have slipped right by me.....
MakDad: you need to measure the distance tooth to tooth on your sprockets....not all clutches, chains, or sprockets are created equal....
Should be 3/8" or1/2".....but it's a BIG DEAL to get it right!!!!!
EDIT: ...Double thanks for the oiling the bushing suggestion....It's always nice to keep what you have already when possible! !!!!
MakDad
Engine is a Honda GC190 - 6 HP.
Front sprocket - 11 teeth. Rear Sprocket - 54 teeth.
Tooth to tooth on the rear axle sprocket is exactly 1/2". The clutch is slightly over 1/2". (weird?).
What is pitch ? I assume that's the measurement I just took ?
Poboy kartman
OK.....Soooo.....that's either a #40 or a #41......the difference being in the thickness of the sprockets and the width of the rollers on the chain.....
#40 is wider.....(I think 3/16".....but not sure).....but often....because thats the only difference.....you get a lot of 40/41 parts....(which means it's wide enough to work on either) .....even though it may be a bit sloppy....they are both 1/2" tooth to tooth.....
Maybe someone will clarify the actual width of the #40 and #41 sprockets.....
EDIT: The variation in measurement on the clutch could be wear.....but....there is nothing that varies less than 1/8" in pitch....so it's either #40 or #41.....
firemanjim
Just kartin' around....
Houston Texas
:welcome2:
Let's not get too far ahead of ourselves and over look an obvious problem..... OP stated kart would run away at half choke.... Sounds like carb needs to be cleaned. You might also try lowering the idle rpm a hair. PO probably upped the idle to keep it running, with a dirty carb, just to sell it to you....
If the clutch grabs, when the rpm is increased, and pulls the kart (with a rider) , then the clutch is working. I've beat the crap out of a lot of clutches, both cheap and high $$$.... A little rust ain't gonna hurt it either. It would have to be really rusted, to keep it from working. And I don't see how it could get rusted in the "engaged" position either.....
I say clean/adjust carb..... And post pics of what ya got going on....
Pitch is how you determine a chains size. A 1/2" pitch means the rollers of the chain are 1/2" apart, but that isn't the only thing that determines the size. You have width and roller diameter too. Typically, on a kart, you would have a 1/2" pitch chain in the sizes of #40 and #41. Chinese karts will run a #420.... The smaller karts, and race karts, run a #35 chain. It's rollers are 3/8" apart, and it's a 3/8" pitch....
Does any of that make sense?
MakDad
Thanks for the detailed replies.
I think you're on to something FiremanJim with the carb issue. The kart will run away at all choke positions, but the reason I mentioned half choke is because that's when it's the strongest.
At choke fully open (pushed in), the engine dies, no matter if it's warmed up or not. I think it might be a separate issue though. I don't mind rebuilding the carb. I've done it on my 2 stroke lawn equipment as well as on my motorcycle Mikuni's. This one shouldn't be too tough either.
Either way, I don't might getting a new clutch for this thing. I'd rather have a new one on there to last a bit. Back to my question though. Will I have to get a 12 tooth clutch instead of my 11 tooth and will I have to modify the chain somehow ?
minibiker
USA
If u have have 41 pitch chain then you will most likely get a 10 tooth which will decrease your top speed and increase your acceleration. I would try fixing the old clutch it may just need oil you would be surprised how long those things last.
No problem poboy kartman just happy to help
firemanjim
Houston Texas
The carb is an easy clean..... Especially if you can do a Mikuni......
I would not suggest going to a 12 tooth , from 11.... Here's why.... You are currently running a 4.9:1 ratio. Switching to a 12 tooth will put you at 4.5:1..... How big are your tires? Small, I hope.... If you got a tire taller than 11"-12", then you want to go the OTHER way.... Like a 5.4:1- 6:1, for 13" tall tires.
If anything, I'd change the axle sprocket to a 60..... How old/big are these "kids"? (don't lie.... You don't have to lie to make friends.... We all ride karts too, and blame it on "kids".... :lolgoku:)
Going to a 12 tooth will increase your top end speed, but DECREASE how fast you can take off, and how long it takes go get to that top speed.... How fast ya wanna go? I mean how fast do you want "them" (;) to go....?
EDIT
:censored: yes, ok, buy a cheap $20 clutch with free shipping, with a 10 tooth sprocket. That puts you at a reasonable 5.4:1..... :thumbsup: but how big are the tires?
EDIT #2
If you have a clutch for #40/41 pitch, with an 11 tooth sprocket, it just MIGHT be a performance,high $$ , clutch. Those, you can get replacement parts, like different tooth count sprockets. Cheaper than buying a new clutch. Post lots of pics, so we can quit speculating......
MakDad
LOL. you guys are funny.
It's mostly for them, they're 12, 10, and 5 although I'm cautious about letting the 5 year old on, even if I'm driving her around. I don't really care about speed TOO much, just want them to have some fun. I'm 180 lbs, and it pulls me good.
So if I *DO* decide to grease it and try it, where exactly is this bushing ? Maybe a pic would explain it better ?
firemanjim
Houston Texas
You see the bolt on the end of the crank, holding the clutch on? Look really close. NO! I said REALLY close! :lolgoku: You see that little brass ring, between the bolt, and the sprocket? Put a drop or 2 of oil right there. Spin the engine over. I ad another drop or two of oil, cuz I'm abusive.... :stir:
That's it... That's all you gotta do. Add a drop or 2, every few hours of use, more frequently , in really dusty conditions...
That brass sleeve is replaceable, and cheap, and easy to remove and replace... :thumbsup: Keep an eye out for excessive slop/side to side play at the sprocket end of the clutch. It's a tell tale sign that the bushing needs to be replaced. Remove the crank bolt, every time you change your oil, and put your eyes on it. Look at it. Does it LOOK like its in good shape? Snug fit, or sloppy? Keeping that bushing up to spec, will save the clutch from un-repairable damage.....
We still haven't heard what the tyre diameter is. All the talk of tooth counts on the clutch and axle is useless without knowing the size of the tyres we are working with
MakDad
After all the research, I'm going to get a new clutch at Northern Tool store that's close to me. Probably 10t seems a good choice. Will I have to modify my chain length with this ?
firemanjim
Houston Texas
Shouldn't have to. You're only going down 1 tooth, so you should be able to simply adjust the tension by sliding engine back a lil further. If you can't tighten chain by sliding engine, you could put a 9/16" nut under each corner (with mounting bolt running through it) but you will need a little bit longer mounting bolts.
The best questions are followed by pics......
