Simple Clone Throttle Setup/Governor Removal
Bluethunder3320
im not sure what ill put this on yet. i tore this engine down and rebuilt with some new parts i happened to have.
i have removed the governor gear out of the engine. i removed the flywheel and hammered a nail on the axle which the governor turns on. it pops out and falls into the engine. now remove the side cover and retrieve these parts. reinstall the governor rod with NO GEAR on it.
like this:
http://i924.photobucket.com/albums/ad86/bluethunder3320/photo-561.jpg
i have also removed the crankshaft from the engine and instead of reinstalling the governor arm, i put a bolt with the head on the inside of the engine and tightened the governor arm onto the other side of the bolt where it sticks out the TOP of the engine.
put the stock throttle link from the governor arm to the carb on.
http://i924.photobucket.com/albums/ad86/bluethunder3320/photo-2464.jpg
run a SOLID LINKAGE in place of the (stock spring) from throttle arm to governor arm.
end result. youll have to mess around with different springs to get the right tension. (for throttle return)
http://i924.photobucket.com/albums/ad86/bluethunder3320/photo-984.jpg
now the throttle arm looks the same as before and will hook up to a cable the same way as before. you can trim off parts of the throttle plate for appearance if you wish. i trimmed off the air filter support tab because im using an aftermarket air filter so i dont need it.
http://i924.photobucket.com/albums/ad86/bluethunder3320/photo-110.jpg
and this way if you want to return the engine to stock (with governor) you have all the parts so you can!!
moderators: if you think anything should be changed to make it more read-able please do so... good luck guys REMOVE THE GOVERNOR AT YOUR OWN RISK!
jamyers
Buffalo Gap, TX
Just curious - why not leave the governor intact and then hook up throttle as you did? You'd be able to override it with your foot, and if you ever wanted to "re-install" it, it'd be a simple matter of re-routing the throttle cable.
Or do governors have a tendency to fly apart at higher rpm?
Bluethunder3320
Added to Helpful links sticky
thanks! glad i can be helpful
Good write up blue! I may just do this, my current throttle setup is not very good.
thanks, i have found that this way is not really common, people usually get rid of everything to do with the governor, but then they lack the structure of "what connects the cable to the butterfly". honda has already designed this for you, just modify it with no governor gear in the engine.
i have never heard of a governor falling apart. on my friends go kart we have tied a string to the throttle arm and the other end to the governor arm so that it is over ridden, or "bypassed". no problems yet. we probably should remove it like this engine, but we took the lazy way and so far it has been fine.
I haven't had it happen, but I am familiar with the internals. If the flyweights were to open too far (caused by engine speed WELL beyond 3600, the button could come off the governor gear shaft. Having this chunk of nylon flying around inside your block could cause some chaos. Also, the internal portion of the governor arm (the "rod" that comes thru the block) has enough of a bend in it that if it were to travel too far, it could strike the crank and/or conrod. More potential for carnage.
Again, it has not happened to me, but the potential is certainly there. It is my own opinion that you are better off removing the internals and eliminating two or more failure opportunities.
Bluethunder3320
agreed, its better to push that enigne to the limits without worrying about anything happening to the governor. the system is eliminated and you are left with an unrestricted engine
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I say that because you can get to about 4000 buy adjusting the throttle stop screw. No point removing the governor for that.
And an engine has no problem to run at 3600 rpm all day? I'm asking because, when I was 10 and got my first Go Kart, my dad always said don't push the pedal to the metal basically, because you can "blow the engine." This is also coming from the same person who said stepping on the gas while the engine is off will flood the Carb. LOL
used2jeep
Massachusetts
Yes they can, construction job site generators as a case in point.
OR "Gold Rush" on the Discovery Channel. heheh
Bluethunder3320
lol, i used to think that when i was like 5. my friend was sitting on this kids mini bike and he was pumping the throttle saying "haha i flooded it for you" but it started up fine and he couldnt figure out how it didnt flood.
That is exactly what they are designed to do. Pressure washers, pumps, gennies, cement mixers, trenchers, augers, tampers- you name it. They all use these stationary industrial engines, intended to run all day in industrial/commercial environments.
Old-school/experienced comment, probably automotive-based. Comes from days when engines had no computer control or other governing methods. Put a brick on the gas pedal in neutral, and you WOULD end up picking up pieces.
Don't LOL too hard- again, old-school auto 101. Pumper carbs had a plunger that would inject fuel even with engine off. To help start a cold engine, you'd pump the pedal a couple times to create a very rich condition, and then turn the key. Our engines are unaffected, but it's not just some crazy old coot's notions.
Badot
Can't speak for all of them, but my motorcycle also has an accelerator pump... twist the throttle and it puts a little spritz of gas through the carb so the mixture stays okay while the slide/needle is still rising.
jamyers
Buffalo Gap, TX
... old-school auto 101. Pumper carbs had a plunger that would inject fuel even with engine off. To help start a cold engine, you'd pump the pedal a couple times to create a very rich condition, and then turn the key. Our engines are unaffected, but it's not just some crazy old coot's notions.
Man that makes me feel old...who'da thought we'd ever be explaining "flooding" an engine?
:oops:
